I cant find a vin # any where on cart but I narrowed it down to a 89 to 94 model need help installing charge receptacle on cart its the crowfoot style its in pic detail A the guy that i bought it from said it was a 48v but its not i bought 2 carts from him 1 was a good cart and 1 was a parts cart the one that was good is the one he said was a 48v but it has a 36v motor and setup but it had a 46v charger receptacle on it and a charge i have it running just need to switch charger receptacle out
need help on install of charger recep
Do the batteries have 3 or 4 fill caps?
If you have 3 caps then it's 36 volt pack - See attached picture for diagram. Fig. F. battery 6 negative, connect charge receptacle negative. battery 1 positive, connect charge receptacle positive(normally connect on f/r switch.
If you have 4 caps then it's 48 volt pack. Fig. A. same as above but batteries 1 & 6 in different location.
Let us know how it works out.Updated by wthompson; February 18, 2014, 06:21 PM.
