96 club car 48volt clicks but does not move
  • 96 club car 48volt clicks but does not move
    hi i have a 96 cc 48 volt it just quit running and now all i get is 50v at bat solenoid clicks ..both terminals on solenoid however have 50v wether gas pedal is pressed or depressed.i checked all the terminals on the motor and they have 50 v at all times I'm not to familiar with trouble shooting these carts pretty good at gas carts.. any help would be great
    So, just because a solenoid clicks doesn't necessarily mean it is functioning correctly. The clicking sound indicates that the solenoid's internal coil is receiving enough voltage to activate the plunger, but it doesn't guarantee that the electrical contacts within the solenoid are making a proper connection. Therefore, we need to test the solenoid's functionality with a multimeter to confirm it’s conducting electricity properly, not just relying on the clicking sound (see solenoid test in attached troubleshooting guide). After that, the next step should be to perform a battery load test to assess their condition accurately. Even though your batteries are showing 50 volts or above on a meter, this measurement alone doesn't guarantee their ability to maintain that voltage under load conditions. Click here to view the battery load test guide
    The sudden loss of power may stem from loose connections, which can disrupt electrical flow and cause intermittent issues. Next, check all connections, battery terminals, solenoid, motor, and controller, to confirm they are securely fastened and free from corrosion. Once verified and all of the above has been checked, proceed with the troubleshooting guide attached to this post. Let us know how far you can get, and if you have any questions feel free to ask!
