Hi all, my resistor ( wwound up wire behind solenoids). Gets really hot after use. Isthis normal? The cart i just purchased is from and auction and a little rough. 87 ds. Is there a printed shop manual anywhere?
Resistor
wiring diagram for your cart. If you remove a resistor or solenoid or speed switch from the circuit you will loose that speed. If the cart runs i would leave it alone. Other than the resistors getting hot, is there another problem with carts electrical?Updated by wthompson; June 24, 2013, 07:20 AM.
Thank you for the reply, i have one soleniod that is melted and the contact to the resistor is unattached. The whole solenoid group appear to have been hodge pogged together to get the cart to run. The drawing isnt very clear so i am unable to see exactly the wiring. I get how it is susposed to work but my main solenoid (first one) has two wires connected to it on the right side going back to the speed controller. Im guessing because the one solenoid is not working? Also i only have one resistor, ( one large wound wire accross all solenoids) is this correct? im seeing on parts supplier web sites there are others for different speeds, how
many should there be? As i said i got the cart at auction and the wiring is so hacked up im replacing it back to otiginal as best i can.
