98 Club Car Slow starts
  • 98 Club Car Slow starts
    Hello All:
    1998 Club Car 48v Regen
    One day after a full charge took it for a 15 minute ride. Off cart for an hour then when I got back on it started slow as putting your car in 2nd gear. It has had a time or two where when you press the accelerator nothing would happen, then it would take off & all would be fine. But now it would start slow all the time & then speed up. Put new batteries in & it still has the problem. Put in local shop, he thought three things. V-Glide, solenoids or controller. He gave up on it. Now the cart won't run at all. I checked 52v's across batteries, batteries are charged. Turn on key switch & nothing, no clicking, nothing.
    Help Please!
    Ronnie
    Did You check for a broken wire on ignition switch ?
      I have a 1987 36 V Club Car,,,,The batteries are fully charged and all Cells check good..When I go to push the gas pedal, my battery meter goes into the red...I have very litlle spead in forward but in reverse it flys....What could be wrong ? Also when in reverse the battery meter stays in the green..
      Updated by bend1969; March 14, 2013, 11:06 AM.
        you most likely have a bad battery or bad connection somewhere in the battery system
