Parking Brake Issues
  • Parking Brake Issues
    I have a 2004 Club Car Precedent. My brakes work fine, but when I am on any kind of hill and try to set the parking brake, the cart will roll until it gets to a flat place. My course at home is rather hilly so it is causing a problem.
    For someone who does not have much mechanical acumen, is there any easy way to "tighten" the parking brake up?
    Any suggestions would be greatly appreciated.
    There is a rod on the back of the pedal which runs down under the cart to a claw that set's the park brake. Look at this claw it maybe out of adjust ment. I have seen the teeth worn off so they want catch also. The rod on the pedal is a snap on so take it loose and adjust it if u can to hold.
      I assume I will need to take the floor board off to see that. The parking brake will set, it just rolls till it finds flat ground.
        OK sorry you said president not DS model my bad.
        Look under floor board and see how much play is in the cables when brake isn't applied. Then set brake and they should be tight. There should be adjustment under the drivers side floor to adjust them.
        Once you find the adjust tighten it up just so the cart want roll.
          Sorry for the possible stupid question (I am by no means a mechanic) what will the adjustment look like and how do I adjust it?
            or and by the way, thanks for information. I have searched the web and not been very succesfull.
              It should be a rod with a heavy duty spring with the brake cables attached to it. Drivers side under the cart.
                One last question, how do I "adjust" it?
                  I was able to fix my parking brake by following your directions. Thank you so much.
                    Glad u gotter fixed. Sorry I couldn't answer the last question. I my self have never done a cart like yours personally yet. I figured it would be simalar to the old style C/C though but wasn't sure.
