Matti,
I found an old thread that DUS started back on June 4, 2009 that pretty much describes the exact same problem I am finding with my 2004 48V Precedent. I have already installed a new solenoid and OBC, but the sporadic failure to run and/or keep running persists. Today I jacked the cart up and it's sitting on blocks to make testing easier. I have removed the floor mat and belly pan cover to access the MCOR wiring and pin plugs. Like DUS described in his thread the MCOR appears to be a sealed unit.
Question #1..........Is there a way to test out the MCOR? (like sticking a needle in the wire(s) to test for voltage back to the controller)
Question #2..........Can you reccommend a site where I can purchase a new MCOR?
Thank you in advance for your help.
