serial #a9728-585491. that is all I know about this cart except it is 48v/ I put new batteries,charger and front plug. It still didn't charge. i changed the obc with another old golf cart and hooking it back up i hooked the neg to a pos term on battery and after i corrected that now the cart wont come on.now after reading some threads I tested the sol. when jumped small term to the neg side of the battery the sol came on and the cart will run. This is the red wire that goes to the contoller. I guess I blew the controller is there a way around this.
97 clubcar golf cart
This schematic should be yours it is 95 to 03 series 48 volt
yes you can by pass the OBC for this function.
Grounded wire and charger came on like it was supposed to. The cart will still not run though the solenoid is not kicking on. I dont have the three wire plug coming out of the motor, just the 4 major wires. so can you help with this problem
Posted earlier by ghoodserial #a9728-585491. that is all I know about this cart except it is 48v/ I put new batteries,charger and front plug. It still didn't charge. i changed the obc with another old golf cart and hooking it back up i hooked the neg to a pos term on battery and after i corrected that now the cart wont come on.now after reading some threads
if it runs and charges your good to go.Updated by gaminde; June 6, 2012, 11:59 AM.
here is another schematic the differance is the controller and the speed switch
Thanks this is the controller that I have. I guess the question I have how do I test the pos side of the solenoid. I unhooked both wires (red/controller) (blkwh limitswitch) I hooked battery back and with key on there was no voltage on either wire.
