I have a 92 Club Car, new batteries.
Something has slowly been going out, and is now mostly out!
Basically, it will not move usually. When it does, you have to slowly push the accelerator pedal.
I have cleaned all of the connectors. Confirmed the solenoid is good by jumping the two big posts and pushing the accelerator.
Cleaned and verified (the best I could) both the F/R and wiper switches.
Still no luck. Really strange, while working on this last night, I was able to get it to go in drive/forward 3 times in a row, then not again.
Here's a little more detail on what's happening:
1 Key on.
2 Moved to F (and R, buzzer works on R)
3 Slowly pushed accelerator pedal.
4 With cover off the wiper switch, I can see the micro-switch in there click when the wiper arm reaches the second copper square. The wiper arm starts at the farthest right spot and moves to the farthest left spot when the accelerator is fully pushed (seems to be adjusted right)?
5 The solenoid clicks right about the time the microswitch in the wiper arm does.
6 NOTHING HAPPENS! OR if you very slowly push the pedal (over and over) it may just start to go, and will run until you stop. Then same problem again.
I don't know what to do next? I really appreciate any advice you can give? Any idea what the problem is? How to troubleshoot further?
Thank you!
1 Key on.
Thank you!
