ds 96 electric club car
  • ds 96 electric club car
    how can i tell if its a 36v or 48v?
    The obvious is how many battery cells does each battery have. 3 are 4
    3=36
    4=48.
    Does it have the crow foot 36 volt charger end are the round 3 prong 48 volt end.
      I Have Changed The Solenoid On My 1998 Clubcar But It Still Want Move All Batteries Are Charge To 8 Amps . I Can Use A Jumper Wire From Post To Post On Solenoid And It Will Work. This I My 3rd Solenoid Today All New Ones .
        Check key switch wiring to V-glide to micro switch inside it.
        Need to check key switch for cotinuity then if it's ok check micro switch inside v-glid.
          Thanks
            I am looking for the diagram to re hook up my motor my so called Buddy unhooked my motor to check the gearing to see about an up grade and did not mark the how to retook it back up with out my permisson it is a 96 cc ds 48v thanks kenny
              This should do it.
                Thank you so much you are a life saver. K
                  My cart is a little different. I have 2 solenoids and f1,f2,a1,a2
                    Posted earlier by bailey264
                    F1 = S1, F2 = S2. If it runs backwards then swap those two cables.
                    This should be it.
                    Updated by andy4639; March 9, 2012, 05:45 AM.
