Chrager lite comes on for about 10 seconds, then off for 30, then on,then off etc. does this wirh key on, key off, running or parked. No loss of power or charge time. Thoughts???
erratic charger lite
BATTERY WARNING LIGHT
Precedent IQ System vehicles feature a dash-mounted warning light (below the steering column) that, when
the vehicle is in operation, indicates low battery voltage or, when the vehicle is being charged, indicates a
charging problem (Figure 9). The battery warning light is controlled by the onboard computer.
SOOOO what we are going to need is each battery voltage with charger off and on and pack voltage with charger on and off
I have a 2007 DS IQ that does the same thing. After finding and reading the manual I found out that this is just a warning light telling you that you haven't charged your battery after using the cart. When the batteries hit a certain discharge rate it comes on.
It doesn't happen if I charge my batteries after each use.Updated by Bone Head Hunter; March 7, 2012, 07:09 AM.
