I have a EZGO Club Car Precedent. The throttle needs to be lubricated because it will not return to the full up position unless I use my hand to pull it back????
Throttle
Posted earlier by pirahablueI have a EZGO Club Car Precedent. The throttle needs to be lubricated because it will not return to the full up position unless I use my hand to pull it back????
Sorry couldn't help myself.
If you are having problems with the the brake, take a hammer and under the floor board tap it a couple of times on the pedal assembly under the floor. If you see dirt coming out of the cracks and such just keep tapping until you get it all out. Then spray everything with WD-40 good.
