2006 Club Car Precedent (48v) - Speed Sensor Repair help!
  • 2006 Club Car Precedent (48v) - Speed Sensor Repair help!
    With the help of a few of the forum members, I have determined that my speed sensor is bad. I have a few questions regarding the repair of the speed sensor.
    1. Does it matter the type of solder you use to connect the hall effect sensor to the three wires?
    2. Does it matter which side of the hall effect sensor faces the inside of the hat? (i.e. which wire connects to which leg)
    3. Does it matter what kind of epoxy you use to fill in the hole?
    4. What do you recommend to keep the wires separated when putting in the hole and epoxying? Seems like there is a good chance they would touch.
    I should also add that I purchased the Allegro A1203LUA-T via Digikey.
    Thanks in advance!
    Gaminde is probably the guy to more accurately answer this but here's my view.
    Send him a PM.
    No problem with any solder, it's not over 350 degrees in there.
    Any 2 part epoxy should work, I use the dual chamber type with the plunger from Home Depot. It's about $5.
      Posted earlier by Carnejm
      Not really but make it quick heat is bad, regular fine solder not silver solder or plumbing solder.
      I always face mine one way but that just makes the wires stick out the same each time check data sheet for orientation
      it can matter if it is conductive or breaks down and becomes conductive
      These are tricks you learn after doing a few just be careful
      Thanks in advance!
      Larry
      Updated by gaminde; December 5, 2011, 06:25 PM.
        OOPS missed one
        which wire to which leg get the data sheet from digikey same page from which you ordered the part from. it has the pin out for that chip and direction information along with detection distance for each side. I don't think it matters on direction in this app. each side reads opposite of the other magnetic pole wise.
        Updated by gaminde; December 5, 2011, 06:28 PM.
          Very helpful! Thank you. I will let yall know how it goes tomorrow.
            Good luck on the fix!
              ah
              is it tomorrow yet
                Posted earlier by gaminde
                ah
                is it tomorrow yet
                It's tomorrow again......
                  Ha ha ha LOL
