I need wiring diagram
  • I need wiring diagram
    I need wiring diagram for a Club Car 2000.5 48 volts.
    Thanks a lot for the help
    Updated by piecab; October 28, 2011, 12:49 PM. Reason: Wrong title
    Is your cart a series motor or sepex motor cart?
    Take a look at this link to help identify your cart: http://www.golfcartsforum.com/genera...-regen-iq.html
      This is a Series Cart
        Sorry for all the questions but I'm working on finding your wiring diagram.
        This is the last question, does your cart have a controller or resistors to regulate the speed?
          I am sorry but I cannot tell you
          Thanks
            i need the same diagram
              I need the same diagram. I believe mine has a controller
                Posted earlier by piecab
                Thanks
                piecab, bgaeke and cobrao4, found your wiring diagram, it's here: http://www.golfcartsforum.com/golf-c...g-diagram.html
                This diagram says it for a 1995 cart but the wiring is the same for 48v series carts with controller until at least 2005.
                The only resistor carts were 36v.
                Updated by dougmcp; November 17, 2011, 10:23 PM.
                  Thank you very much, but I am not sure about it. My clubcar has 2 red small wire that connect on battery ?
                  Thanks a lot and have a good weekend
                  Pierre
                    Pierre
                    Pierre, Can you take a photo of what you are referring to and post it so we can see what the red wires are?
                      It is impossible at this moment to take a picture because the Car is stored for winter, but the 2 wires are red and were connected One on - of battery 6 and the other one on battery 1
                      Thanks
                      Pierre
                        Those wires could be for battery charging or they could go to the state of charge meter. If they are 10ga or so it's probably the battery charging leads if the wires are 14ga-18ga they are probably for the meter.
                          For sure, it about 16-18 gauge
                          Thanks
                          • #14
                            Thanks Dougmcp. This is exactly what I was looking for. Quick question do you have the legend key for the diagram. a description of what the numbers designate. I am hoping it will tell me what gauge. wire is used
