I bought an 05 CC that has only been used about 6 time. It has the original 12v Trojan batteries which I am going to replace in the spring since I am going to store the cart away in a month. The cart runs fine and I have the charger on the cart as we speak and I was looking the batteries over and I can see the sides are bulged out. The cart was stored in a heated building so I know they have never been frozen. What causes this and should I be concerned using the cart for a month?
Another Battery Question
As batteries age they tend to bulge and it is generally not a problem, even new batteries have a wee bit of a bulge.
Check the temperatures of your batteries while they are charging, if they get hot you should replace them (warm is normal).
Posted earlier by dougmcpSounds like they have nearly outlived their life. Depends on how much and how far you want to drive the cart next year, who knows, you might even squeeze another year out of them.I have the money put aside so I will take the plunge in the spring
2005 CC Precedent
Give this some thought, you may even be able to run them next spring and save up a little more for the 6x8v conversion. The cost of the 8v batteries and the conversion may be just a little bit more than the 12v batteries.
End result would be longer battery lifespan and better run times.
Posted earlier by dougmcpGive this some thought, you may even be able to run them next spring and save up a little more for the 6x8v conversion. The cost of the 8v batteries and the conversion may be just a little bit more than the 12v batteries.
End result would be longer battery lifespan and better run times.2005 CC Precedent
I agree somewhat that the conversion may cost a little more. If you are not in need of the extra run time and possible battery life issue then a conversion may be a waste of time and effort.
As far as the OBC goes, these things are not smart enough to tell the difference between 4x12v batteries and 6x8v batteries. Club Car has had issues in past with their OBCs and have had changes and upgrades.
The newest one is CC PN 103446601 which is the 4.0 version of their OBC and it is the same number required for a replacement from CC regardless of whether the cart has 4x12v or 6x8v batteries.
One more new development I have found is that Sam's Club is now starting to carry 12v golf cart batteries. They are $184 each but so far I have only seen them on the East coast. I believe they may be made by East Penn/Deka.
Still 12v at $185 each, 4x12v would be $740 and the 8v at $80 each, 6x8v would be $480.
That's a $260 difference which brings your conversion cost to a net $140.
These are all just an exercise in possibilities and food for thought, not intended to recommend one way or the other.
Posted earlier by dougmcpI agree somewhat that the conversion may cost a little more. If you are not in need of the extra run time and possible battery life issue then a conversion may be a waste of time and effort.
These are all just an exercise in possibilities and food for thought, not intended to recommend one way or the other.2005 CC Precedent
