I have a 1990 Club Car 36v v-glide with resistors. Is it possible to replace the v-glide with a controller and if so what parts would I need?
1990 Club Car
This article will start to get you in the right area http://www.golfcartsforum.com/golf-c...-48-volts.htmlRegards
I think there is a way to use the V-Glide but I also believe in order to have your cart work properly you would also need to change out the V-Glide with a PB-6 potbox for the throttle.
Before you go too far, the resistor set up is pretty reliable, why do you want to change it to a controller?
Parts alone will cost in the $400-$500 range and it won't have any more power or go any faster.Updated by dougmcp; September 20, 2011, 03:55 PM.
Posted earlier by dougmcpI think there is a way to use the V-Glide but I also believe in order to have your cart work properly you would also need to change out the V-Glide with a PB-6 potbox for the throttle.
Parts alone will cost in the $400-$500 range and it won't have any more power or go any faster.Regards
Posted earlier by MattiWell you do get a smoother take off, but that is about it.
Waiting to hear why wcraver wants to change it.......Updated by dougmcp; September 20, 2011, 07:56 PM.
The only real thing the controller does is give you better run time on your batteries.
A controller cart uses a throttle input to control the power that goes to the motor by a rapid full power pulse similar to the way a household light dimmer works.
Hot resistors is a normal function of the cart and will not hurt anything.
A resistor cart applies full power all the time and uses the resistors to control speed by bleeding off excess energy in the form of heat.
The slower you go, the more resistors are being used.
The 1st speed uses all 3 resistors, 2nd speed uses 2 resistors, 3rd speed uses 1 resistor and full speed uses none with all the power going to the motor.
Posted earlier by dougmcpThe only real thing the controller does is give you better run time on your batteries.
The reason I ask is because I switched from 6x6v batteries to 3x12volt batteries. I know, I know, I've read other threads about doing this.
I realize that the reverse power wire was connected halfway across the line so reverse was 18 volts. On three 12v batteries, I have a choice of applying 12, 24, or 36vdcto the reverse circuit.
Right now, I have the reverse power cable only on the "first" battery, supplying 12vdc to the reverse. It is slow, thus I have to make sure I'm going down a small slope when backing.
The safety factor is also a concern here with the coils. If you ride a lot in the tall grass during the hot dry summer months you could start a fire with this type of cart very easly.
#1 change over to a controller is a good idea if the money isn't a concern.
The v-glide can be used but you need one with the grey connector on it. The one in your cart now works off of the cart voltage. It see's 36 volts where the one you want only see's OHM'S 5k-0 like this one.
This should be yours here.
This is the one you need for a controller conversion.
Once you have this v-glide the rest is easy. Just wire it for a controller cart.
Posted earlier by timfluryAlright, so how about reverse??
