Hi, I just bought a used 2005 electric club car Precedent. Added a rear facing seat and adding a light package. I am adding a voltage converter in stead of a voltage reducer to save the batteries. I need to know where to get the 48 volts from for the converter - the wiring diagram and instructions for the light kit are not good. Where should I go for this information.
Club Car owner
to GCF wjbrace.
I was under the impression that all Precedent carts came with a voltage reducer that converts 48v to 12v for the accessories.
I'm a little confused as to what your plan is and what your definition of reducer vs a converter.
The wiring diagram for your cart is here: http://www.golfcartsforum.com/golf-c...g-diagram.html
My understanding is that a reducer is smaller and runs off just (2) of the batteries and a converter wires all (4) batteries and converts 48v to 12v so that the draw on the batteriers is equal for all (4) batteries so that when you hook up the charger all of them get charged equal time - increasing the life of the batteries. The instructions that came with the light kit are poor. It does'nt indicate that the Precedent already has a voltage converter which might explain why I can't find the blue wire that the instructions tell me to hook the fuse to between the battery and the blue wire that provides voltage to the wiring harnesss for the lights,and horn. Where would the voltage reducer/converter be on this cart?
Thanks, Bill
Please help my understanding. I thought the converter covered all four batteries in a 48 volt cart (i.e. 4 12 volt batteries or 6 8 volt batteries). It seems to me to be the most simplistic in terms of battery charging and linking light kits. I'm brand new at this and just want to understand the rationale of only hooking the light kit to one 8 volt or 12 volt battery. This is feasible; however, the current draw is not equal and I would think that one would want to extend all batteries the same.
ZackMan
Posted earlier by ZackManPlease help my understanding. I thought the converter covered all four batteries in a 48 volt cart (i.e. 4 12 volt batteries or 6 8 volt batteries). It seems to me to be the most simplistic in terms of battery charging and linking light kits. I'm brand new at this and just want to understand the rationale of only hooking the light kit to one 8 volt or 12 volt battery. This is feasible; however, the current draw is not equal and I would think that one would want to extend all batteries the same.
ZackMan
Posted earlier by trigger1937Can anyone tell me what the power drain,..ie Wattage,.is for the light kits on Club Car Precedents. I know they are 12 volts and halogen bulbs but just how much current do they draw. Also, what is the 12 volt draw on the rear tail lights and the turn lights???
To give you some perspective, your lighting totals about 110 watts while the motor while cruising is about 3600 watts.
If you're not using the lights for long periods of time they can be wired to 1 12v battery.
Posted earlier by johnnyjDoug, i'm wanting to hook up a cigarette lighter on my 07 with 4 12 volt batteries. Can i use any of the batteries to do this? If i understand Matti's post this is right. Thanks Johnny
