Not sure if this is the correct area to post this so please move if necessary. Golf carts are all new to me and my owner of the company I work for has three club cars. I have an opportunity to purchase a 2005 club car president that was his mothers who never really used it. It looks brand new and has the original batteries, mirror, headlights and taillights and is programed for a higher speed. He would sell it to me for $2,100.00 and wonder if this is a good deal. When I say not used much, it looks brand new so mint condition would be a better word. I also assume since it has four batteries it would be a 48volt cart?
Need input
Posted earlier by erictNot sure if this is the correct area to post this so please move if necessary. Golf carts are all new to me and my owner of the company I work for has three club cars. I have an opportunity to purchase a 2005 club car president that was his mothers who never really used it. It looks brand new and has the original batteries, mirror, headlights and taillights and is programed for a higher speed. He would sell it to me for $2,100.00 and wonder if this is a good deal. When I say not used much, it looks brand new so mint condition would be a better word. I also assume since it has four batteries it would be a 48volt cart?
Posted earlier by gamindeThere are variable factors and one is the area you live in. I have seen 06's for $1000 to $1500 your going to need batteries soon $1000 light kit $200 and $150 for speed mod.2005 CC Precedent
to GCF erict!
Sounds like a nice cart and a privately owned one IMO is way better than a thrashed out retired golf course cart.
Regardless of how much it was used the Precedents from 2004 to 2009 have a weak point, the batteries tend to last only 2-3 years.
The price is probably OK for a mint cart but if you purchase it count on replacing the battery pack which will cost $800+ depending on where you shop.Updated by dougmcp; September 7, 2011, 07:06 PM.
Posted earlier by dougmcpto GCF erict!
The price is probably OK for a mint cart but if you purchase it count on replacing the battery pack which will cost $800+ depending on where you shop.Why the short battery life during these years?
2005 CC Precedent
Good call on the private owned versus golf course cart. I had to replace the whole front end on mine a lift kit replaced everything for about the same price as repairing it. You need to check craigslist, ebay and the newspaper for prices in your area. Mine is an 06 original batteries and runs strong. Now that I said that I know they're going to die tomorrowUpdated by gaminde; September 7, 2011, 07:24 PM.
Posted earlier by erictThank you for the welcome. So every 2-3 years I will be sinking $1,000 each timeWhy the short battery life during these years?
Club Car makes a conversion kit for about $350 that will convert to the 6x8v set up. It includes battery racks, new OBC, cables, instructions etc. and IMO is well worth the investment if you are having to buy new batteries.
You can get 6x8v batteries from Sam's Club for less than $500 and would put your conversion costs at less than $1000 and have a battery pack that should last 5-7 years.
If you buy the cart I can get you the CC part numbers for the conversion.
Posted earlier by gamindeNow that I said that I know they're going to die tomorrowand probably true.
As you know maintenance of your batteries is key to their longevity and you take care and have the knowledge to do so. The odds of yours failing prematurely are slim.
Posted earlier by dougmcpIt has been such a problem for Club Car that in 2010 they changed the battery configuration from the 4x12v set up to a 6x8v set up that they had been using on the DS model for over 10 years.
On a side note, I will see if he will at least have the batteries load tested and test each cell with a hydrometer.Updated by erict; September 7, 2011, 08:16 PM.2005 CC Precedent
They are likely Trojan Batteries in the cart the date code stamped into the lead on the neg post is a letter and a number which is the month and year they were produced (eg: H-7 is July 2007).
Take a voltmeter and test the voltage, a perfect, older 12v battery with a full charge will be 12.73v.
State of charge for a 12v battery is:
100% - 12.73v
80% - 12.50v
50% - 12.10v
30% - 11.81v
10% - 11.51v
If the batteries are charged and any of the voltages are under 80% they are likely done.
You don't need to disconnect anything to do the voltage test.
Keep us informed and let us know how it's going.Updated by dougmcp; September 7, 2011, 08:45 PM.
Posted earlier by gamindeI'm looking into lithium ion half the weight and over three times the distance have not costed it out yet.
there was a company, I am not sure if it was completely legit or not, who emailed me through this website a few months ago I will see if I can bring it up if you would like.
edit, just looked I cant seem to find the company. I will let you know if I happen to remember where I got the email.Regards
Posted earlier by Matti$$$$
If I do the battery conversion and change the OBC, does this effect anything else like the spped adjustment that was done on this cart? Remember this is all new to me.
Also, is there a chart that shoes me what the readings should be if I do a hydrometer test of each cell?Updated by erict; September 8, 2011, 06:50 AM.2005 CC Precedent
Posted earlier by erictIf I do the battery conversion and change the OBC, does this effect anything else like the spped adjustment that was done on this cart? Remember this is all new to me.
Here is your chart with voltage and hydrometer readings:
Posted earlier by dougmcpYour speeds shouldn't change, the program is in the controller and nothing changes there.
Here is your chart with voltage and hydrometer readings:2005 CC Precedent
Maybe after he sees the batteries are done or close to it he may come down a little in price or offer some concession for replacement of same.
It all depends on what your plans are for a cart, if you are looking for trouble free with little or no repairs other than the obvious batteries, you would be hard pressed to find a cart for $2K that is in mint condition.
IMO golf carts are not like cars that change from year to year, they stay pretty constant until they introduce a new model.
There is really no difference between Precedents made from 2004 to present other than in 2010 they changed the battery configuration.
The Club Car DS model has remained virtually the same since 1981 with the exception of the electrical, little has changed. This is true with Ezgo as well with the TXT cart that has been in it's current form since 1994.5 with only changes in the electrical systems.
Posted earlier by dougmcpMaybe after he sees the batteries are done or close to it he may come down a little in price or offer some concession for replacement of same.
The Club Car DS model has remained virtually the same since 1981 with the exception of the electrical, little has changed. This is true with Ezgo as well with the TXT cart that has been in it's current form since 1994.5 with only changes in the electrical systems.2005 CC Precedent
Posted earlier by dougmcpGood luck with the battery test and negotiations.
Keep us posted.Updated by erict; September 8, 2011, 12:00 PM.2005 CC Precedent
If the battery level of charge is too low, the CC 48v charger will not engage. What he is trying to do with the 12v charger is to bring the individual batteries up to a point that the CC charger will come on.
He may not even get it to charge if the batteries are seriously done.
If you load test these batteries they will fail.
I wouldn't say too much to him about batteries let him find out by himself the cart won't charge or run.......I can hear the price dropping as I type.
Posted earlier by dougmcpIf the battery level of charge is too low, the CC 48v charger will not engage. What he is trying to do with the 12v charger is to bring the individual batteries up to a point that the CC charger will come on.
I wouldn't say too much to him about batteries let him find out by himself the cart won't charge or run.......I can hear the price dropping as I type.Updated by erict; September 8, 2011, 12:39 PM.2005 CC Precedent
He is only charging 12v so he will have to connect to each battery one at a time until the voltage comes up. You do not need to disconnect anything to do this.
The seller is not familiar with the CC charger. If the pack voltage is below 34v, there is a procedure to use the CC charger to recharge depleted batteries. It involves removing the cover on the charger and jumping the relay so it will come on and charge the batteries.
I have the manual on this for later reference.
Posted earlier by dougmcpHe is only charging 12v so he will have to connect to each battery one at a time until the voltage comes up. You do not need to disconnect anything to do this.
I have the manual on this for later reference.Looks like I will take it home with me tomorrow as it's just to good of a deal. Showroom new
2005 CC Precedent
Posted earlier by dougmcpCongrats on the purchase.
Well, did it run?
Did you have to pay the full asking $?
2005 CC Precedent
I didn't have time to check the cart after work and will tomorrow as far as how or if they charged. They have the Trojan batteries which I know are the best but cost alot of $$$$. I'm also aware as Doug pointed out about the conversion kit as an option. Is there any cheaper batteries that do a good job? Does Costco carry any?Updated by erict; September 8, 2011, 05:33 PM.2005 CC Precedent
Unfortunately 12v deep cycle battery choices are few, they are only made by a few companies and they are fairly expensive.
If you are going to do the conversion, now would be the time.
See if you can get the batteries up to a point of being able to operate the cart.
Can you post the voltages of each battery?
Posted earlier by dougmcpUnfortunately 12v deep cycle battery choices are few, they are only made by a few companies and they are fairly expensive.
Can you post the voltages of each battery?2005 CC Precedent
You can safely wash your cart with a hose but I would avoid pressure washers.
If you are washing the battery area try to keep water off the electronics, they'll take moisture but don't like flooding.
To give you some basics on your cart and become a little more familiar, go to the Club Car site and download the owner's manual.
Here's the link:http://www.clubcar.com/resources/own...s/default.aspx
You will need your serial number that is located in the pass side glove box area and should look like this:
Posted earlier by dougmcpYou can safely wash your cart with a hose but I would avoid pressure washers.
Thanks Doug. I have the original owner’s manual in front of meWe only charged two of the batteries and was able to get the CC charger to turn on now even though the other two batteries are in a very low state.
Updated by erict; September 9, 2011, 09:30 AM.2005 CC Precedent
Posted earlier by dougmcpLet the CC charger run and do it's job. It could take up to 16 hours to complete it's charge routine.
After it's done let the cart sit for a couple of hours then take the battery voltages and post the results.
Also, how do I know when it's fully charged?Updated by erict; September 9, 2011, 11:11 AM.2005 CC Precedent
Posted earlier by erictAlso, how do I know when it's fully charged?
You can dance through the battery voltages with a meter while it's charging.
You will see that near the end of the charge cycle the amperage falls off and the voltage rises.
A 48v charger in it's equalization stage will be at around 60v to 63v before shutting down. Based on that, each battery will be 15v to 15.6v.
You don't need to disconnect anything and you won't hurt anything by taking voltage readings at any time.
Posted earlier by dougmcpThe charger should shut down by itself. The CC uses a thing called an on board computer (OBC) which determines the charger function.
14.08
13.09
12.89
12.71
The first two readings are the batteries that were first charged a little with a regular battery charger.2005 CC Precedent
Based on your numbers, the batteries have a ways to go before they are charged if they even will fully charge up at all.
Usually the weakest battery will have the highest voltage readings while being charged.
Because batteries of different voltages are confusing to discern while charging, figures normally used by battery and charger manufacturers are expressed in volts per cell. 6v batteries have 3 cells, 8v - 4 cells and 12v - 6 cells.
A bulk charge stage is normally applied at about 2.4v per cell (14.4v for yours).
The finishing charge (equalization) is about 2.6v per cell (15.6v for yours).
If you have a 3 stage charger the float stage is about 2.25v per cell (13.5v for yours).
When your batteries all approach the 15.6v +/- each you will know the charger is ready to shut off.
If the charger shuts off early, unplug it and restart the charge cycle.
Anything over 2.5v per cell (15.0v for yours) will cause them to boil, this is normal so don't be alarmed.
Make sure the area is ventilated as there is also hydrogen gas being released and it is explosive.Updated by dougmcp; September 9, 2011, 12:39 PM.
Posted earlier by dougmcpBased on your numbers, the batteries have a ways to go before they are charged if they even will fully charge up at all.
Make sure the area is ventilated as there is also hydrogen gas being released and it is explosive.Updated by erict; September 9, 2011, 01:25 PM.2005 CC Precedent
Posted earlier by erictI have a load tester from work (digital) but I need to enter the CCA which the Trojans don't show. How can I load test them correctly?
Deep cycle batteries are rated in Amp Hours (AH) or minutes of capacity at a specified amperage.
Rather than using a load tester, you may do better by noting the voltage and hydrometer readings after charging and a 6 hour rest.
Sorry I can't be of more help.
Try this tutorial from Trojan and see if it helps: http://www.trojanbattery.com/Tech-Su...nglish_003.pdf
Posted earlier by dougmcpGorgeous cart and at first blush worth the price.
I see the battery light on the dash and what is the purpose of it. It would light up when I had the cart in neutral I think. It was never on when running the cart.Updated by erict; September 9, 2011, 09:57 PM.2005 CC Precedent
2005 CC Precedent
