I'm back again with another problem. I have a club car 81 model 36 volt. All the solenoids except the 3rd solenoid has 36 volts on both small posts. I know one small post should have 36 volts on each solenoid and the other should be the ground or no voltage. Any suggestions what could be causing voltage on both small posts? Also, I'm getting 36 volts on each big post that has the bar that connects them all together but not the other big posts. I have a wiring diagram but none of the wires are in diagram are color coded and hard to tell where they go and connect to. Please any suggestions!
Club Car 81 36v not running
Posted earlier by nbirtI'm back again with another problem. I have a club car 81 model 36 volt. All the solenoids except the 3rd solenoid has 36 volts on both small posts. I know one small post should have 36 volts on each solenoid and the other should be the ground or no voltage. Any suggestions what could be causing voltage on both small posts? Also, I'm getting 36 volts on each big post that has the bar that connects them all together but not the other big posts. I have a wiring diagram but none of the wires are in diagram are color coded and hard to tell where they go and connect to. Please any suggestions!
Still haven't figured out why I can't get the solenoids to activate. On the F/R switch should the positive from the battery go to the solid lug so when you switch from forward and reverse you get power on both. Cause the I got is wired battery positive to one of the lugs and solid lug is wired to motor. I also noticed that the wire that comes from the F/R switch to the last solenoid was wired to the post on solenoids that has bar connecting all five together. I noticed on schematics that it was supposed to go the back post so I switched it to that post. Any suggestions why still not working or power to solenoids?
Sorry I'm late to the party.
With the key in the off position check the continuity on the large posts of the offending solenoid if has a connection the solenoid is bad if it is only when the power/key is on it is a bad micro switch controlling that solenoid.Updated by dougmcp; August 25, 2011, 10:12 PM.
Here is a picture with some tips.
Put red lead of meter on 36 + and black on each solenoid and see if it reads voltage as you depress the gas pedal. I had one that skipped the 2-3 solenoid because some one wired it up wrong.
Here is the schematic for the same cart.
