I just bought a 2010 Club Car Precedent Champions Edition. It has an aftermarket light kit with lights, turn signals and horn. Everything works except the brake lights. Horn works, front and rear lights work, turn signal works, but no brake lights. Does anyone have any idea where a newbie like me should start problem shooting this? Also, I just checked and the lights work even when the cart key is turned off. Is there a way I can rewire this so the lights only work when the cart is on?
2010 Club Car Precedent Brake Lights Not Working
Aftermarket light kits don't always have the brake light function enabled or may not even have a brake light switch. You will need to confirm you have a switch. A quick call to the previous owner should take care of that.
Normally the converter is on all the time but a simple $3 relay can fix that.
If you turn your converter on and off with the key switch, any stereo memory would be lost and you won't be able to use the 12v accessory plug unless the key is on.
You have 5 posts so you can read the resources section. Your schematic is located here: http://www.golfcartsforum.com/golf-c...iq-wiring.html
Posted earlier by dougmcpYou have 5 posts so you can read the resources section. Your schematic is located here: http://www.golfcartsforum.com/golf-c...iq-wiring.html
Can you check if I posted the relay schematic its for reducer but could also be used for lights I'm on my phone and everything is sooooo small
Posted earlier by gamindeDougmcp
Posted earlier by JantreeWhose forum? Would love the schematic.
If you have any questions just ask
and by the way it uses the charger relay so you will always have a spare, about 5.00.
I have a list of parts not sure its here or not if you need it let me know.
Matti is there somewhere where I/you can post a file and be able to update it?? I have started a parts list very small at this time, others may be able to add to it. stuff that can be purchased from places like digikey, mouser, jameco
charger relays 36 and 48
diodes
Datel two wire metersUpdated by gaminde; August 17, 2011, 03:59 PM.
Posted earlier by gamindeMatti is there somewhere where I/you can post a file and be able to update it?? I have started a parts list very small at this time, others may be able to add to it. stuff that can be purchased from places like digikey, mouser, jameco
diodes
Datel two wire metersRegards
Posted earlier by MattiLike post a thread and be able to edit it? or actually upload files in a thread and then at a later date, upload some more files to the thread?
I'm thinking whoever wired this thing didn't know what they were doing. I noticed tonight that the blinkers only work when the headlights and taillights are not on. When the lights are on, no blinking. Does anyone have any ideas or is it better to pull it out and start from scratch?
Posted earlier by JantreeI'm thinking whoever wired this thing didn't know what they were doing. I noticed tonight that the blinkers only work when the headlights and taillights are not on. When the lights are on, no blinking. Does anyone have any ideas or is it better to pull it out and start from scratch?Regards
Need to take a deep breath this really doesn't sound that far off, you might need to power things differently. It might just be the 1 wire on the light switch and with a relay your done.
What matti suggested is your best start, post a copy here ill be more than happy to help you.
Posted earlier by gamindeIf you have nothing to do pull the dash down 3 screws and Ill bet there are three wires coming from the light switch tie two together and your fixed.
now your going to ask which two aren't you !!!!
I removed the floor mat and floor board and found that the brake light switch was not connected. I connected it and brake lights now work. I have head light, tail lights and brake lights. The turn signals and flasher don't work. Horn does work. This light kit looks like the precedent ultimate light kits you see on the web. Any ideas will be helpful.
Ok I think your going to have two problems even though you only have one now.
pull the dash down there will be three wires connected to your light sw
C power to light system
nc going to turn signals
no going to lights
so when you turn your lights on the turn signals are turned off, connect the NC wire (NC normanly closed) to the main power or C = common
this gives power to turn signals weather lights are on or not.
now with your parking break set do the brake lights stay on ????
and I think a relay from the key sw might be a good Idea because turn signals can be left on
Posted earlier by gamindeOk so what changed what work has been done. Brake sweet wires were they connected to each other disconnect them see if blinkers work something changed what was it.
All I did was connect the brake switch. orange to red and then brown to black. Then the brake lights worked. I haven't disconnected anything else. There is a three prong female receptacle (two connectors with wires to them, one with two wires) with nothing connected to it. I am wondering if that is where the flasher should connect? I don't see a flasher. I am wondering if it fell out or it there was never one connected?
Jantree, you will need a flasher in order to make the signal lights flash. I believe the Precedent has LED's so you will need an electronic flasher capable of working with the LED lights.
Signal lights are pretty universal as they all generally use the same signal light assemblies.
Have a look at this and see if it resembles what you have: Precedent Turn Signal Instructions
You may also have a timer on your brake lights but it may be disconnected.
Look at this for a little clearer picture of what I am talking about: Precedent Brake Light InstructionsUpdated by dougmcp; August 28, 2011, 09:13 PM.
Good call gaminde, I just reread the first post and it says:
Posted earlier by JantreeIt has an aftermarket light kit with lights, turn signals and horn. Everything works except the brake lights. Horn works, front and rear lights work, turn signal works, but no brake lights.
I can't see wiring in the brake switch causing the signals to malfunction unless something is miswired or shorted to ground.
If there's a fuse in the system, I'd check it again to see that it's still OK.Updated by dougmcp; August 28, 2011, 11:08 PM.
My signal kit looks more like this: http://www.mymadjax.com/file/Ultimat...Installweb.pdf.
If I have time tomorrow, I will open dash and take a few pictures and show you what I think is the flasher receptacle. Thanks for all the ideas.
I think I have the problem solved. I called MadJax and talked with John. From what I described, he said I need a flasher and brake light switch timer. I purchased both and they are on the way. I willl post pics of the install and hopefully, all will be well. He confirmed that I need an LED flasher. Since the turn signals did work earlier, he guessed like I did that the flasher came loose. I will check behind the dash to see if I can find the old one. Otherwise the cart is great. Does anyone know where I can pick up a service manual for a 2010 Precedent.
I have a service manual for the Precedent from 2004 when they first introduced. Not much has changed on these other than the OBC part numbers and the new 6x8v battery layout in 2009/10.
The service manual does not address anything about accessories like lights but covers everything else.
Send me a PM with your email address and I will send it to you. It's 13MB in size so make sure your email will handle it.
