1986 club car 36v
  • 1986 club car 36v
    Im looking for a f/r switch wiring diagram any help will be greatly appreciated thanks
    Hello here you are http://www.golfcartsforum.com/golf-cart-diagrams/466-club-car-ds-85-86-87-88-36v-wiring-diagram.html
    you need 5 posts to view diagrams, only 3 left!
      Thanks for the help
        Hope to get it running soon
          I'm sorry to bother you again but I'm not aloud to access the diagram for some reason what should I do
            Is there another way to access it
              Read this article here http://www.golfcartsforum.com/introd...-diagrams.html
                Is it ok to use 3 12 volt deep cycle linked to 36 volt or would they drain to fast. Just looking for alternatives. Or would 6 12 volt linked series and parallel work better it would still be 36 volt. Any suggestions
                  If it is a 36v cart, the best combination is 6x6v Golf Cart batteries.
                  Best price I have seen, value vs performance is Sam's Club at about $72 each.
                    I used 3 12v regular car batteries for a couple of years. Not as good as 6x6v but will work. It is best if you have a steady supply they won't last as long as deep cycle batteries.
                      Even if I use 12v deep cycle marine batteries
                        Yep anything that = 36 volts will work, but as doug said, the less amount of batteries that you use, the less run-time you will have.
                          I also own 1986 CC. A wiring schematic for that yer would be nice as I have spent months working out the wiring on the cart. Come to find out the A1 terminal was not as expected on the electric motor.
                          Updated by Bull1000; January 8, 2017, 03:46 AM.
                          • #14
                            I have a 36 volt Club Car that will go in forward/reverse with key off. I installed a kill switch that prevents it from going forward, but even the kill switch in off does not stop it from going in reverse. Not sure where to look. Any suggestions?
