Do I need a new spindle or what?
  • Do I need a new spindle or what?
    My rear wheel locked up!
    I have a 1984 Club Car electric that I bought used 11 years ago.
    I use it every day winter and summer.
    We heat our house with an outdoor wood furnace.
    I even keep the furnace going all summer, just to heat the hot water.
    I cut wagon loads of wood and use the golf cart to pull them to the furnace.
    I install tire chains in winter otherwise the tires just spin when we get freezing rain.
    There really isn't enough clearance between the tire and the suspension,
    so last fall I installed lug spacers that I bought on eBay.
    They give an additional 1.5 inches of clearance.
    My driver's side rear tire locked up today and started dragging.
    I found that 3 of the lug bolts were missing completely,
    and the fourth was disconnected from the spindle.
    The lug bolt just rotates freely.
    The lug nuts were still connected to the spacers.
    I assume this is the rear axle.
    The lug bolt extensions don't have much to do with your problem.
    You either have a locked up rear brake, bad wheel bearing or frozen differential.
    Is there any oil in the rear axle? When did you change it last? How did the wheel stay on with only 1 lug nut?
