What octane level should I run in my golf cart?
  • What octane level should I run in my golf cart?
    Golf cart manufacturers recommend running only 87 octane gasoline. If you are located in a high altitude level, or running your golf cart under high loads or heavy use you may benefit from a higher octane gasoline.
    Octane determines the rate in which gasoline burns. A higher octane makes the fuel burn slower, and vice versa.
