How Do I test an electric motor?
  • How Do I test an electric motor?
    Series Wound Motor:
    There are 4 connections on the motor, we'll use the following as an example. A1, A2, F1 and F2. The letters could differ. Put a jumper wire from A1 to F1 so they are connected. Now jump the A2 and F2 connections with a 12 volt battery or battery charger. It does not matter which polarity. If the motor is good it will turn over.
    Shunt Wound Motor:
    Again there are 4 connections on the motor, we'll use the following as an example. A1, A2, F1 and F2. The letters could differ. Put a jumper wire from A1 to F1 so they are connected, and another separate jumper wire from A2 to F2. Now run a current from a 12 volt battery from the A1/F1 connection to the A2/F2 connection. It does not matter which polarity. If the motor is good it will turn over.
    To learn more about which motor you have, check out this article located here.
