How Often Do I perform an engine oil change?
  • How Often Do I perform an engine oil change?
    A simple engine oil change can lead to a long healthy golf cart life and save you a lot of time and money in the future. Oil changes should be performed on all gas golf carts semi-annually or after 125 hours of running time.
    Key Tips:
    • Drain oil while engine is still warm. (Not hot!)
    • Drained oil should be pure with no large or obscure objects in it.
    • Tip or jack up the cart to ensure all the oil or debris has fully drained.
    • Clean oil filter with a solvent or replace.
    • Refill engine with SAE 10W-30 or 10W-40 motor oil that meets or exceeds SF, SG, CC oil.
    • NEVER overfill
    *Help keep the earth a clean and healthy planet. Always collect and dispose of used oil in the proper and legal manner. Contact your town or state for disposal guidelines.
