How Do I put my PDS EZGO into diagnostics code mode?
  • How Do I put my PDS EZGO into diagnostics code mode?
    If you have a PDS EZGO (forward/reverse switch on the dash) when in the event of a problem you can enter the golf cart into diagnostics mode to help find out what is wrong with your cart.
    To enter diagnostics mode turn the key switch to off, move the run/tow switch to run, move the direction switch from neutral to rev 5 times. The cart will beep to confirm you are in diagnostics mode. After that, the diagnostics code beep will sound if there is a problem. When you are finished move the run/tow switch to tow.
    Click the attachment below to view the beep code chart.
