A recent Reddit post by a dismayed golf cart owner serves as a poignant reminder of the significance of meticulous attention to instructions, highlighting the potentially costly consequences of oversight.
The individual, the owner of a electric 72V lead acid golf cart, found themselves in a week long deadlock due to what they initially assumed was a battery issue. Having meticulously maintained the batteries by regularly topping off the water levels—aided by a Trojan watering system, the unexpected failure of the batteries, stamped with a March '21 date, came as a surprise.
Convinced that the batteries were failing, the owner started contemplating replacement options. The prospect of six 12V lead acid batteries loomed large, estimating a minimum cost of $1400 or more should they opt for lithium batteries as an alternative.
However, a twist of fate unfolded during a last ditch investigation before making the hefty investment. The owner, in a stroke of realization, decided to physically test the gravity of each cell, only to discover a baffling oversight: two batteries were diligently connected to the watering system and maintained in impeccable condition, while four batteries, hadn't received a drop of water in over a year.
The shocking revelation of these bone dry cells prompted a change in strategy. With a renewed sense of hope, the owner plans to revive the neglected batteries, hoping for a miraculous resurrection. Nevertheless, the specter of a costly mistake lingers, leaving a bitter taste of regret for the initial oversight.
This cautionary tale serves as a poignant lesson—a testament to the profound impact of meticulous adherence to maintenance protocols and the steep price of oversight. This golf cart owner's story resonates as a reminder to all, emphasizing the importance of thoroughness, attention to detail, and the perils of assuming when it comes to equipment maintenance.
The outcome, while still uncertain, stands as a testament to the value of a comprehensive examination before reaching conclusions. For this golf cart owner, it's a $1600 lesson—The pivotal takeaway is crystal clear: remove assumptions and embrace precision. For all those traversing the paths with their electric golf carts, it's time to remove all watering systems (and assumptions) and diligently check each individual battery water level when needed, ensuring each battery receives the water (and care) it deserves.
