I have 2017 ezgo 48v I just purchased... being new to owning a cart...I plugged the charger to the cart then the wall... then I read you should plug into the wall first... did I screw something up?
Charging batteries
No, you likely didn't damage anything by plugging the charger into the cart first and then the wall. Most modern chargers are designed to handle either sequence without causing harm. Just follow the recommended sequence (wall first, then cart) in the future to ensure optimal safety and performance.
- Likes 1
Posted earlier by Jack PalmerNo, you likely didn't damage anything by plugging the charger into the cart first and then the wall. Most modern chargers are designed to handle either sequence without causing harm. Just follow the recommended sequence (wall first, then cart) in the future to ensure optimal safety and performance.
