Limp Mode - No Safe Mode - Speed Sensor????
  • Limp Mode - No Safe Mode - Speed Sensor????
    I have a 2003 - 36volt - EZGO.
    Here is/are my problem(s)
    Runs at a very slow speed, but, if you move the engage/disengage the run/tow toggle, it will run right for about 30 feet or so and then goes back to a very slow speed.
    Also, the Safe mode, that keeps it from rolling away if you forget to set the brake does not work.
    Batteries are fully charged, about 37 or 38 volts
    Diagnostic code is 1-3, chart says "speed sensor"
    Replaced speed sensor --- No change to speed problem or safe mode problem.
    Could I have gotten a bad replacement sensor?
    Does anybody else have any ideas about what the problem could be?????
    Any ideas??? Anybody????
    Thanks in advance!!!!
    One other note...When I replaced the sensor, I removed and inspected the magnet that is attached to the end of the motor.
    No chips, cracks or deformities found.
