I recently purchased an 88 2 cycle ezgo that will fire straight away, run for 15-20 seconds then just die.
I have put in a new fuel pump, a new carby kit with float level adjusted correctly. All new fuel lines and dip tube, I have removed the engine to clean and adjust pulse coil as per the book. I have good spark even when i check it straight after it dies.
I have removed the exhaust to eliminate blockage but problem persists.
I have cleaned and checked reed valves.
The engine is turning in the right rotation.
Compression is 125
Have changed the plug (twice)
I dont have much hair but i am tearing out whats left over this supposedly simple engine.
Compression is 125
