how much of a lift kit is good
  • how much of a lift kit is good
    I want to put a lift kit on a 94 ezgo is it wouth the extra money to go 6" or more?
    Depends what you want to do with the cart, the lift may be just the beginning.
    What do you envision as a completed cart, where will you drive it and what kind of terrain will it be on?
    Is your Ezgo gas or electric?
      Posted earlier by dougmcp
      Thanks for the reply
      Its gas and mostly its just a campground runner I would like to make some trail for carts with it. So I know I need some tires. My nephew had adaptors made by the local school for free so he can use 4-wheeler tires I may do the same.
        Gas carts are pretty forgiving when they are lifted so you shouldn't have too much trouble. If the terrain you are using it on is not too extreme, a 3"-4" lift should be fine and the center of gravity remains low so the cart is more stable.
          Posted earlier by tspeed
          If you really care about function over form then 6inches is more than enough. Width is just as important for stability in off camber situations.
            Spoken with authority for a new member with lifted cart experience.
              Thanks Guys
              I think getting to a point where I can use ATV tires is plenty and they are easier to come by with good tread. The off-camber thing is important there is a good sized hill where we are...
                Thanks Guys
                Im basing my theory on what the guys rockcrawling are doing. Their vehicles are still giving them ground clearance but they are not sitting extremely high like some of these mud trucks you see. Lower center of gravity and width helps you hug the ground better in the off camber situations.
                  Lifts look good but they really are unsafe the higher you go. The rock crawlers use a width and lots of wheel travel up and down. You want the center of gravity to be as low as you can get it. The draw back on width is most trails are narrow so it becomes a problem with going to wide also. I have seen long travel carts not make a trail because of the narrowness in betwen tree's.
                    Thats a fact about long travels. Thats why Id never use one unless all I did was dunes riding.
                      Posted earlier by ak47fan
                      I want to do that some day!
                        Posted earlier by andy4639
                        I went duning at the Silver Lake Dunes in Michigan one Saturday and it was out of this world. I used a Polaris RZR for that trip. Take the Monster cart up there and put some paddles on the back!
